series working along path autodesk inventor
  • Thread starter Thread starter rbxlnx
rbxlnx
I should do a series work on a curved path, I tried with series but it is not possible, I also tried to search online but I couldn't find anything, someone can help me?
thanks to all
Good morning.
repetition could be done in two ways so cold.
  1. (so that it is not intuitive) rectangular series, select then repeat on path
  2. set guided by sketch, in this case should insert the points where repetition must have effect to have an optimal result
Hi, can you put the sketch of the path and indicate the type of processing you want to serialize?
