set an adaptive color of the pointer
  • Thread starter Thread starter poryhawaii
poryhawaii
a detail that I don't know how to solve: the color of the pointer. on another pc I have the classic white pointer, but if it passes over lines or white/clear objects it becomes black to be visible comuque. on my pc instead white is and white remains.
I found the window to change the color, but I don't find an "adactive color" option.
for now I have solved by putting the ucs colors, but when a command is selected (e.g. moves, where the pointer turns into square) back to being classic white.
that I know the adaptive color for the pointer does not exist. If your problem is the color of the plant you put below, try to save it in pure black and white (1 bit). inserting it in autocad you will have the possibility to change its color as if it were an object (line, circle etc)
This is what I mean by "adaptive color": the black on the left is the classic background of acad, the one on the left is a .jpg image inserted. the pointer is normally white (when it is on black background), but it becomes black when it is on white background (or clear in general, it happens on white of the image, as on yellow of any line).Immagine.webpbut I have it on another pc with acad 2014, on my I can't even export/importing the user profile
I also acad 2016, same problem, very annoying.
I didn't find any solutions and live with it.
I hope in the next release.
