pro-matteo
Hello everyone, use pro-e wf3
I have to change the classic display of hidden lines.
in ittaic are gray and continuous and I would like red dotted.
for the color I have already done, I changed the color file whose addressing is visible in my config.pro that I allego.
I just can't find the file or strings that control the line types.
Does anyone know where they can be?
I tried to open the model of my active design, but I don't find it (I also attach this)
config.pro:!
pro_font_dir c:\configuration_wf\font
pro_material_dir c:\configuration_wf\materials
pro_crosshatch_dir c:\configuration_wf\campiture
pro_format_dir c:\configuration_wf\formati
pro_dtl_setup_dir c:\configuration_wf\configuration_messa_in_table
mdl_tree_cfg_file c:\configuration_wf\shaft_model\tree.cfg
pro_symbol_dir c:\configuration_wf\simboli
pro_plot_config_dir c:\configuration_wf\plotter
!pro_library_dir c... .
format_setup_file c:\configuration_wf\configuration_messa_in_tavola\active drawing.dtl
symbol_instance_palette_file c:\configuration_wf\simboli\draw_symbol_palette.drw
tolerance_table_dir c:\configuration_wf\tabelle_tolleranze\iso
search_path_file c:\configuration_wf\mappatura.pro
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------system_colors_file c:\configurazione_wf\optional_color_shemes\syscol.scl
pro_colormap_path c:\configurazione_wf\tavolozza_colori\
!trail files
trail_dir c:\temp
set_trail_single_step yes
!layer
def_layer layer_assem_member componenti_di_assieme
def_layer layer_axis feature_con_assi_o_cosmetiche
def_layer layer_skeleton_model scheletri
def_layer layer_surface superfici
def_layer layer_datum_plane piani_di_riferimento
def_layer layer_point punti
def_layer layer_copy_geometry copy_geometry
def_layer layer_curve curve
def_layer layer_csys csys
def_layer layer_curve_ent entità_curva
def_layer layer_dim quote
def_layer layer_note note
def_layer layer_gtol tolleranze_geometriche
def_layer layer_snap_line linee_snapand now my metric.dtl model file
drawing_text_height 4.000000
text_thickness 0.000000
text_width_factor 0.800000
broken_view_offset 1.000000
create_area_unfold_segmented yes
def_view_text_height 0.000000
def_view_text_thickness 0.000000
detail_circle_line_style solidfont
detail_circle_note_text default
detail_view_circle on
half_view_line solid
model_display_for_new_views hidden_line
projection_type first_angle
show_total_unfold_seam yes
tan_edge_display_for_new_views default
view_note std_iso
view_scale_denominator 0
view_scale_format decimal
detail_view_boundary_type circle
detail_view_scale_factor 2.000000
crossec_arrow_length 3.000000
crossec_arrow_style tail_online
crossec_arrow_width 1.000000
crossec_text_place after_head
crossec_type old_style
cutting_line std_iso
cutting_line_adapt no
cutting_line_segment 0.000000
def_xhatch_break_around_text no
def_xhatch_break_margin_size 0.150000
draw_cosms_in_area_xsec no
remove_cosms_from_xsecs total
show_quilts_in_total_xsecs no
datum_point_shape cross
datum_point_size 0.312500
hidden_tangent_edges erased
hlr_for_datum_curves yes
hlr_for_pipe_solid_cl no
hlr_for_threads yes
location_radius default(2.)
mesh_surface_lines on
pipe_insulation_solid_xsec no
ref_des_display no
show_sym_of_suppressed_weld no
thread_standard std_iso
weld_light_xsec no
weld_solid_xsec no
allow_3d_dimensions no
angdim_text_orientation horizontal
associative_dimensioning yes
blank_zero_tolerance no
chamfer_45deg_leader_style std_asme_ansi
chamfer_45deg_dim_text jis
clip_diam_dimensions yes
clip_dimensions yes
clip_dim_arrow_style double_arrow
default_dim_elbows yes
dim_fraction_format default
dim_leader_length 0.500000
dim_text_gap 0.500000
display_tol_by_1000 no
draft_scale 1.000000
draw_ang_units ang_deg
draw_ang_unit_trail_zeros yes
dual_digits_diff -1
dual_dimensioning no
dual_dimension_brackets yes
dual_metric_dim_show_fractions no
dual_secondary_units mm
iso_ordinate_delta no
lead_trail_zeros std_default
lead_trail_zeros_scope dims
orddim_text_orientation horizontal
ord_dim_standard std_ansi
parallel_dim_placement above
radial_dimension_display std_asme
shrinkage_value_display percent_shrink
symmetric_tol_display_standard std_asme
text_orientation iso_parallel
tol_display no
tol_text_height_factor standard
tol_text_width_factor standard
use_major_units no
witness_line_delta 0.125000
witness_line_offset 0.062500
default_font font
dim_dot_box_style default
draw_arrow_length 2.000000
draw_arrow_style filled
draw_arrow_width 1.000000
draw_attach_sym_height default
draw_attach_sym_width default
draw_dot_diameter default
leader_elbow_length 0.250000
leader_extension_font solidfont
axis_interior_clipping no
axis_line_offset 0.100000
circle_axis_offset 0.100000
radial_pattern_axis_circle no
asme_dtm_on_dia_dim_gtol on_gtol
gtol_datums std_iso
gtol_datum_placement_default on_bottom
gtol_dim_placement on_bottom
new_iso_set_datums yes
stacked_gtol_align yes
2d_region_columns_fit_text no
all_holes_in_hole_table yes
dash_supp_dims_in_region yes
def_bom_balloons_attachment edge
def_bom_balloons_snap_lines no
def_bom_balloons_stagger no
def_bom_balloons_stagger_value 0.600000
def_bom_balloons_view_offset 0.800000
def_bom_balloons_edge_att_sym arrowhead
def_bom_balloons_surf_att_sym integral
min_dist_between_bom_balloons 0.800000
model_digits_in_region yes
reference_bom_balloon_text "default"
show_cbl_term_in_region yes
sort_method_in_region delimited
zero_quantity_cell_format empty
draw_layer_overrides_model no
ignore_model_layer_status yes
model_grid_balloon_display yes
model_grid_balloon_size 0.200000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset default
model_grid_text_orientation horizontal
model_grid_text_position centered
pipe_pt_line_style default
pipe_pt_shape cross
pipe_pt_size default
show_pipe_theor_cl_pts bend_cl
decimal_marker comma_for_metric_dual
default_pipe_bend_note no
drawing_units mm
harn_tang_line_display no
line_style_standard std_iso
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius default
pos_loc_format %s%x%y, %r
sym_flip_rotated_text no
weld_symbol_standard std_iso
yes_no_parameter_display true_false
config.pro:!
!trail files
trail_dir c:\temp
!layer
view_note std_iso
hlr_for_threads yes
ref_des_display no
weld_light_xsec no
weld_solid_xsec no
clip_dimensions yes
dual_digits_diff -1
tol_display no
use_major_units no
default_font font
gtol_datums std_iso
pipe_pt_shape cross
drawing_units mm
node_radius default
