Shotfree
good morning to all, I recently passed from the use of creo to solidworks, in using this sw I could not do without noticing that the system of constraints for the realization of the assemblies (if as I understood it) is something unmanageable (naturally if we talk about assembling with a certain number of components, not with 3-5 pieces on the cross). the problems I have encountered are:
Are things actually like this or is there a way to view the constraints of a single object?
thanks for your sharing and for the answers, I wish you good continuation.
- once all the components are bound, the set of constraints for each of them becomes "mostruous" and the interaction between them is almost "uncontrollable" (I reversed the normal coupling on a component and overturned the component on which this had to be bound instead of turning the component itself)
- I do not have the possibility to immediately identify the 3/4 constraints that determine the stable (completely bound) positioning of my objects (especially if I have many details bound to a single object).
