inthesky980
hi, I have a problem in setting a z axis safety distance in milling for processing a piece on a horizontal center. I try to explain myself better: I have to work a block on 3 faces, I have created the 3 setups where I went to perform the jobs I need. when I went to read the code nc I noticed that using a tool on all 3 faces, during the rotation of the table, the tool on one side takes off me in z of about 5mm and on the other it takes 330mm. to make me understand better: I have to do centering on all three faces: start from g56 and the table is put to c270 I do the centerings then the tool breaks me about 5mm and step to g55 turning to c90, I make the centerings, the tool now comes off of me 330mm and step to g54 to c0 and I do other centerings.
I would need that before any rotation of the table the tool would break at least 200mm. I don't know where to change, whether in processing strategies or post processors.
I hope someone can help me
