set the cartilage permanently
  • Thread starter Thread starter Cergil1983
Cergil1983
Good morning to all, I would need to understand how I permanently set up a cartilage used for table harvests with inventor. I understood how to make a 'personal' cartiglio, but every time I make a new table with a new project does not appear my cartiglio, only the default one appears.. how do I set my cartilage permanently?
thank you in advance for the answer, good work to all
Take your file with the modified folder and save it in the same template folder (with other name) I should find the standard.idw. when you make a new table, select your own.
to know where the templates folder is, go to files and click on options below.
a mask will open with many folders.
click on the file folder.
under default models there is a button with written above configures default model.. .
just below is the template folder of your installation.
put your file there with the new cart.
Remember that if your cartella is called iso, which I believe is the default name of inventor, it will be easier in the future to automatically update your carts in your archive, if you want to change it, simply using tools made available by inventor.
