set version of catia in opening
  • Thread starter Thread starter Teopado89
Teopado89
hi, I installed the r19 and r22 release on the same pc at work.
every time I create a file opens by default the r22.
Is it possible to set that open by default the r19?
In theory, you should open the casket first and then the files.
However, if you don't have plm, one of the possibilities is to go to the cat part and catproduct file, property button, general, open with , change , select the same cnext that starts your v5 r19 icon on the desktop. should change for all files. Just that if you already have v22s, then it doesn't open to you.
I don't know if there are other ways.
as the reader said is fine,
I also add that if you have multiple versions, to avoid "belt disease", better change the background color according to the release, so that you immediately notice which you are using, otherwise if you save a product with the upper version, you stick to a juniper.
ps I think we can set the start from the catenv (the catia environment file reserved for systemists).
years ago
