setting color quota sketcher
  • Thread starter Thread starter davide_pontini
davide_pontini
good morning to all, use creo 3.0
My problem is as follows: I want to change the color of the weak odds in the sketch.
I go to the system color, I change the color only of that quota, I carry the syscol file in the folder where the config.pro reads it, I overwrite it and I think the game is done.
On the other hand, by making the counterent between the syscol vechcio (previously slaved) and the new one I do not find any modified voice and in fact by entering into it I find no voice that identifies me the ones of the weak quotas.
What's wrong?
Hello, hello, hello.
I use creo 2.0, so I can't give you any specific indication for creo 3.0, but I can give you generic advice to make sure that the program actually reads the syscol file you expect.
generically I can tell you the option creo 2.0 to return to the config.pro to map the file, (but I think you already know):
system_colors_file c:\config_creo2\syscol.scl
and as last I suggest to try to temporarily exclude your syscol (setting it in another folder or rename it) and restart the program so as to 100% check if the program reads that specific file or another, in that case you do a file search inside your c:.
Try and let me know, hello!
