Marcava
Hi, guys.
I use a hd2 license. for preliminary analysis on the style surfaces to be applied to my catpart I have to check the strip (or angle of deformed) relative between a surface of revolution and another that runs around him (I cannot attach images, unfortunately). the problem is that, being these with a variable angle compared to my axle, with the normal "feature draft analysis" I get a false figure (because it is related to an axis of the terna and not between the surfaces). I have literally r... to make sections and counter-sections on a table to have still not accurate data. purely aesthetically, I can run sweps along the edge of encounter between the two surfaces and correcting the angle (in this case relative to the dominant sup.) and see if they are within the admissible range.
someone has some advice: Additional licenses, commands not visible and/or not in use normally,... I also have a cac+mce license and a basic dmu kinematics.
Thank you in advance.
ps. on nx 10.0 I found the function, but aime does not run with license as5010.
branded
branded
