sform analysis
  • Thread starter Thread starter giutech
giutech
hello to all, I kindly ask you how I can do a deformed analysis given an abstraction axis, the command I already know where it is, but I can't interpret the analysis!
How can I set the degrees to do the analysis?
Can't anyone give me a tip?
Please, it's important! Be patient I come from catia v5 and for some things I don't really feel safe!
Thank you so much!
It seems to me that the subject has already been dealt with, however:
mine is in English, in any case you press from the drop down menu annalisys--->face--->shape---->slope
then select an axis (printing axis)press ok.
at the top you have 3 windows with fields to be compiled to the left write for example -2 and to the right 2 (you will have a control range from + 2 to -2 degrees)
select all geometryprems ok and color everything from fuxia to blue with intermediate gradations.
or analsys---> shape ----> draft
+ or - it works the same way, personally I prefer the first.
Palo
Okay, thank you. I kindly ask you one last thing, is it possible that there is not this option you suggested to me?
slope, it means inclination and in my analysing-face-form tendon-it gives me radius, reflection, tangency, distance, and with the other system does not give me the possibility to change the angle!
Bo! I don't know... if you can make me clear!
hi giutech, to be able to give you a possible exhaustive answer I need to know which modules of nx you have available .
this to understand whether your license has the appropriate modules.ù
... slope, it means inclination and in my analysing-face-form tendon gives me radius, reflection, tangency, distance, ...
the command that rightly suggests you paolo_go, in the installation in Italian, corresponds to "tangence".
also works with the simple mach1
