share an open corner
  • Thread starter Thread starter gil
gil
I am asking for this thing, even banal therefore I was ashamed a little, but what to say. I can't do that.
in the quotation of a default autocad angle always measures the smaller angle formed by 2 segments. see example, it is noted that autocad insists on saying 90°.
angolo.webpIf I wanted to quote the opposite corner, what makes 270° as you do?
x marcobi
Unfortunately not. move the quota but continues to refer to the smallest corner. as from image.
x tristan
Thank you. I took a while, but with your suggestion I found the “truck”.
Do you explain to me the trick? :smile:
There is no "truck". Launch angular quota command and before specifying the first point accept default option <specifica vertice="">, then click on the top of the corner and then the two directions that define its amplitude; at this point you can choose whether to quote the inside or the outside. That's all folks!</specifica>
I went to search for the impossible and instead with a couple of button dx you get to the solution! ! !
