share parameters between parts together
  • Thread starter Thread starter ansyolitico
ansyolitico
if you want to share the paramentaries of some parts with others in a set or assemblies as you could do?
if in a set I create a parameterized part like a tube, after I create another and I create bonds of coincidence on the first part, modifying it through the paremeters also the second... but if this together the amount in another set, I make a linear pattern, how do I depend on the distance of the pattern from the width of the tube that is part of a subset?
Is there no way of having shared relationships?
if relationships are in "simple cascade": that is, part that conditiones a set that in turn affects a higher level set, there are several possibilities, both at the level of 3d mathematics, and at the level of parameterization.
but you have to be careful how to use these "relations", already the only rename them, sends everything in cascade, with loss of information even quite serious for the database.
said this, it is necessary to analyze the specific case, already I create has the ability to automatically recognize the series of components and/or assemblies of the lower levels, then there is the flexibility that can be given also to the parameters as well as to the quotas, finally the relationships allow to recall quotas or parameters, of the components and/or assemblies of the lower levels, through the drop-down menu above the tab of the report window; then there are measuring and evaluation features, which can be used in many ways.
depends on the case you have and what you want to get.
Unfortunately not, but a tutorial on a street, may not be the best choice for your case.
in practice the vertical tube I bound geometrically to the horizontal tube , but what I wanted to do was that changing the width of the tube the pattern took that quota as offset ....only that I do not know how to take that quota... I think that if I had to do it manual semantically I should pass it id-pezzo.quota.... from the relations menu I can not
Sorry the banalita of the question.. .
if the link of geometries is made with the "copy geometry" ok, tie them together directly is an external reference that will break the boxes.
Binding the series offset to geometry is not a problem.
If you double-click or change the geometry where there is the share you need, then opening the relationship window, selecting the quota, ends in the relationship window.
But if I wanted to draw a plate to lean over the horizontal tubes with the ends matching the tubes?... if the number of tubes changes is a mess
are all things that a skeleton would solve, however by experience, eye to want to tie everything together, it seems efficient, but if you have to recycle the project or worse, the components, you can turn out to be boomerang.. . .
