TECNOMODEL
I guess I'm banal, but I've been banging my head since Friday and I'm not in charge.
in the environment together I would like to model using some odds that are common between several parts.
an example to clarify:
model a matrix with an interasse between two locations that I define with a quota.
I therefore create a new part and I have to create two holes with the same interasse of before. I would therefore like to insert that quota in the window in which the functions of the quotas are inserted in order to make that varying the entire quota within the matrix also the entire quota of the new part.
I can reuse quotas within one part, taking them, for example, from a feature.
I can't do the same between different parts, even if in the guide I find written that it is feasible (the procedure is not written to do so).
Thank you for your help.
