share value in brackets
deep70
Hello, girl. Can you tell me that they mean quotas in brackets?? I don't remember..:-(((()
Hello. .
means that the quota is not functional, in the sense that it could be derived as sum or difference of other quotas on the design, and is added for convenience of the operator.
The odds out of scale once indicated with a hyphen under the quota line at the figure, maybe the legislation changed?
p:s: sorry opps I didn't realize we were in the building forum... .
you are right, the value out of scale is indicated with a hyphen below....
in the old legislation (mechanical... I don't know in construction) the quota in parentheses was an exact quota. Now (well...from a lot) was replaced with rectangle around the quota.
Of course I don't think it makes sense to talk about "exact price" in construction, where there are no geometric and form tolerances, or is there?
Hello hunting
What you write is exact
but in the specific case may mean more
if that is a mechanical design
can mean it's the starting share
in practice if you have to drill on a cn the "0" in x or y part from them
from the sketch do not see signs of work on the side
could be a smooth drawn rough
in other cases
the quota in brackets also means that it is a quota already repeated in other places
here the legislation says that in a mecc design you can not repeat the same quota several times
in all these cases
I never put the prob!! ! !
I always called:biggrin:
except if the inn is indicated the meaning
or you have the capitulate of the company that spends your work
Let me know the evolution
a hug
the quotas in brackets are the useless quotas and rigor not to put.
In case of example, it's a mistake to share a whole series and then put the total, as a rule, the series should be "open".
in cases where it is believed to help the operator (do not make him use the calculator) it is allowed to put an "auxiliary" quota in brackets.
a "gentile" way not to force "the operator" to make small amounts.
:smile:
:smile:
hello president
we would need to see all the design
to determine what the prog actually wants to transmit to the operator
there are no significant regulations that vingolino certain writing choices quotas
in one specific case you put parentheses
when you have double value in mm and inch
It's just the complete vision of the design that gives you the idea of what they mean
certain quotas
Moreover we do not know what type of operator the design is intended
my respective president
:smile:
In fact the quota I added after "apposed", I did not send in the workshop that design! :rolleyes:
But here we were talking about building and conventions are likely to be different.
Bye.
Bye.
ambeh!!
Save, for a little while, but save!
:biggrin:
for the mechanics quoto hunt, for the ahimè construction I have no idea.
Bye.
:smile:
in mechanics is as stefano says (pardon.. er President :smile:), always.
out of scale are underlined (they were, with manual paperwork, when you changed quotas on the copy and pencil on the polish to update -mai-, not to have to do everything again).
I don't know for sure.
Mar
well if you want to put on to your share value in brackets then follow some 2d concepts. first of all specify the one-dimensional and two dimensional points. then specify its criteria of points.then give the specification in coordinate points or values.in autocad also need to spefication of its rectangles angles also.
cap , dwg cad
