if the real size is your model.. You can do it with the lathe.hi guys, in the annex I created a half lid of a tank it is possible to remove the vertical wall and the semicircle above transform everything into sheet metal and make it develop?
Thank you in advance.
you can create flanges on curved profiles, but the flanges are cone logs.I think swx does it too (you know from version 2009).
I would like to point out that the processing of sheet metal is not my job, so I could write cows, but I wonder if the development of that paper is then correct. if the software manages to develop funnels I do not understand why it is necessary to remove from the model the back that in the real sheet instead there is and is formed during the funnel.you can create flanges on curved profiles, but the flanges are cone logs.
these sw manages to develop, but the final part of the piece is an arc on conical part and sw fails.
Is the pro/e sheet module integrated into the basic licence ?
you say it develops without back, but you can't tear the edges or erase the wall and create a flange, clearly in pro/e, since sw can't?
Sorry, but why did you mention me?I would like to point out that the processing of sheet metal is not my job, so I could write cows, but I wonder if the development of that paper is then correct. if the software manages to develop funnels I do not understand why it is necessary to remove from the model the back that in the real sheet instead there is and is formed during the funnel.
is it not that it makes a brutal calculation of the development of the chord without taking into account the parameters of deformation of the imbuted plates and for this it needs that there is not the back part?
Perhaps the same development calculated by a specific software for iumbutiture is different, that is, and correct. . .
correct ... he needs a fem calculation and not a geometric developmentI would like to point out that the processing of sheet metal is not my job, so I could write cows, but I wonder if the development of that paper is then correct. if the software manages to develop funnels I do not understand why it is necessary to remove from the model the back that in the real sheet instead there is and is formed during the funnel.
because you were the untimate intervened assuming that it was a problem of the swx plate module, while to me it seems that the process of calculation of the spreadsheet of a process of funnel requires calculations other than those for bending. I therefore assumed that the result of that development done in pro-e and catia in the sheet metal module was wrong.Sorry, but why did you mention me?
Hello solid, I answer:you can create flanges on curved profiles, but the flanges are cone logs.
dear marco, as it was rightly observed, in that case we do not talk about development from funnel, the sheet metal module of pro/e allows to make the calculation standard of straight or curved folds but not of development for imbuted sheets (the programs that do this are highly specialized and cost a proposition, I know one that costs 50,000 euros per year of rental ... do not sell it).because you were the untimate intervened assuming that it was a problem of the swx plate module, while to me it seems that the process of calculation of the spreadsheet of a process of funnel requires calculations other than those for bending. I therefore assumed that the result of that development done in pro-e and catia in the sheet metal module was wrong.
You have... Of course you can do but it is made in several pieces, and therefore it is all another story than what you requested.Egregi gentlemen, mine was just an example thrown them with random measures.
for my incompetence I have not been able to remove the vertical wall and the semicircle above, as the reality of the reservoir is yes that profile but with an external radius from 2 meters for 360 degrees. the smaller hole that would form above (diameter 80 cm) is however disassato non coaxial and moved to the left of trunk 30 cm regarding the diameter of 4 meters. (They are stainless steel tanks for high food 7 mt).
question: with solidworks 2011 can you create everything and develop it or not? Can you make a step?
Hello, everyone.
hello you could have said right away what you were interested in as developed geometry of funnel typeEgregi gentlemen, mine was just an example thrown them with random measures.
Hello, everyone.
