sheet metal
  • Thread starter Thread starter kionn
kionn
boys good morning
excuse me but why does not make me the development of the sheet,and bring development in .drw format use pro.w3
I can't believe you don't create development.
mail the file prt!
to display the development in the table as first you create a regular flattening / flatten everything.
then go to change/set/state plan/create/insert a name/completely flat/selection the flattening done before/yes
now you have created a family table with the flattened part.
All you have to do is call her back to the table.
I'll work you out.
Thank you very much,
was a problem of too small rays: (...they are beginner. . . )
feel lollone I don't know wrong but on the table I can make the lines where the bending is carried out if it is possible how it is done?
Remember that the fold radius depends on the knife used by the press.
Moreover, each radius size corresponds to a "dev" value or a k factor.
then check if development is actually right.
to view the fold lines (see files that I attached to you before) on the properties of view/visual view/style viewing tangent edges put no one.
then go to the exhibition/cancella and view the axes on the view and you will see that they appear.
