sheet size with custom size
MARCOC
hello to everyone, and the first time I happen to use a custom sheet format, i.e. not an a4...eccc, and the little nice thing that happens and that in the cartiglio rightly appears the written "custom size (mm) in the sheet format field, someone knows how to solve the problem? ? ?
I tried to create a sheet format by giving it a name, but he always puts "custom size (mm) in the paper!
You have to change the property to which that field refers.
For example, you can enter a "demand entry" so you can fill it manually.
hi technomodel. .pultroppo manually and a solution that I cannot adopt. .must be a field that automatically compiles, otherwise too many errors are created
then you have to create an ad hoc property to be inserted in the template and point to this in the folder.
that you know you can't run a sheet format to the standard inventor list??? and I don’t say what makes you create within idw files, which after appear in the standard list, because those always keep the name of the starting model
