sheet thickness in the paper mill
  • Thread starter Thread starter Tarkus
Tarkus
I would like to insert the sheet metal thickness in the paper mill, but when I open the text editor, between the list of properties of the sheet, it only shows the area the length and width of the flat model.
how to insert the thickness property into the list of types on the text editor to insert it into the cart? :confused:
it seems to me that the iproperty collection had this possibility to insert even the thickness
I say it on the fly, without trying, but the "thickness" parameter in export cannot do your case then on the table?
swipe the fx button, next to each variable there is a check casel. if you put the check there the variable can be used as a custom property and used in the list parts at the table.
take a look also quiciao!
with i-proprety collection you should have 2 values, sm_style puts the value of the sheet style (I created all the thicknesses example 10/10 15/10 20/10 etc...) while sm_thickness is the value in mm thick. . .
ah,you meant export parameter.
it works as long as the part to be inserted in the drawing has been made with a sheet model where the thickness parameter in export is checked,
Otherwise it must be popped from time to time.
for iproperty collection: I didn't try because I feel like they don't go on 64-bit systems.
However thanks to the drittes:finger::biggrin:
Hello thank you x straight
Question? ?
how can I control the
number of decimals? ?
dx button on list parts-change list parts.
dx button on the affected column - column format.
I still haven't tried
but does it also work in the cartilage? ?
this solution
Thank you again
