sheets, sw object snaps and traces
  • Thread starter Thread starter -Mc-
-Mc-
Hello, everyone!
software: sw 2008 sp 4
I have a few questions...
- are there sw-object snaps that allow you to use the apparent intersection?
I would need to quote in the technical table the vertices (where instead I have the fittings of the folded sheet).
- plate development tracking: what method do you use? I am looking for the simplest and fastest (as well as manageable).
the snap is not because the odds must be physically attached to something, to put them in a theoretical edge use virtual sharp. select the two sides before the connection and click the dot command of the sketch. a quoteable virtual sharp appears.
What do you mean? are not enough notes of solidworks?
Okay, thank you. It's the method I'm already using.
by means of traces I mean lines "traced" by the laser (i.e. the head of the laser "drawn" these flaws on the sheet) to allow welders to already have the position of the pieces to be welded on the sheet: that is, the lines drawn by the laser with the shape of the pieces to be soldered and with its short position;
to make this use a sketch on the welding axieme, contouring the edges of the various welded pieces; the problem is that when I open the flat repetition I don't get the sketch marks.
