Garrett
I have a problem with dynamic simulation of a shock absorber, this is the design
I've been looking for some tutorials around that could help me but I couldn't get over it, I bet it's stupid for you.
I have this shock absorber and I would like to do 2 things:
1) by applying a force from below or from above I would like to make the spring compress and then slide the stem
2) at the 2 extremes of the shock absorber there are 2 spherical uniballs, I would limit the ability to excursion of this uniform and make sure that when the bushing collides with the body of the shock absorber the ball stops and does not go any further (if you are not well understood what I intend to tell me)
I have placed the following constraints:
the bottom unball is bound pin/hole with the stem
plates supporting the spring on the 2 sides are also bound for pin/hole, one with the stem and one with the body of the shock absorber
the stem is bound to coincide between its axis and body axis of the shock absorber, in fact it is free to flow
fixed these constraints went on dynamic simulation, I positioned a f force from the bottom up and I launched the simulation, but nothing moves.
Where is the huge mistake that definitely exists in all this?
