Yes but without manco 2 data...Bye to all,
I wanted to ask you the following question.
with what theory would you verify the resitent section of this lever?
could you fit in the case of a lifting hook?
for band bass, you're right there's a little bug around that hole.Yes but without manco 2 data...
p-h
the answer is always that:biggrin: the science of constructions, 2 accounts and you know where helmets.http://it.wikipedia.org/wiki/azione_esternaalbertfor band bass, you're right there's a little bug around that hole.
hp: lever stuck at the hole
load: applied on the free extremity of the lever
Type of load: strength p and torque moment
the question remains the same, with what theory do I verify the section of the lever?
Hi, I didn't get the ready parrot, I was just asking if the hook theory could be okay, but the idea of 3 framed beams I don't mind.If you want ready parrot, use aise-tr7-76 ladle hooks design (specific for lamellar hooks used in steel field) with the firmness that you do not have a circular throat.
However, given the simplicity, I would do two hand accounts with three framed beams
