simplified rep also loads "excluded" objects
  • Thread starter Thread starter panzer92
panzer92
Good afternoon to all,
I am dealing with managing a very large set and to be able to do it smoothly I am using extensively the visualizations.
made this premise I have the following doubts:
1) when I create a simplified rep, what I decide not to represent, which I exclude, is only hidden from my sight or I create does not consider simplifying calculations much? the doubt arises from the fact that in the tree on the left I find all the components that I have instead excluded.
2) if the components, whether they are parts or assemblies, which I have excluded having to make mistakes, is it correct that you find them in the simplified representation and in the aid in which it is recalled?
thanks in advance for the help
Good morning.
1) excluded components are in fact excluded from calculations. in the model three you see them but side by side you should also have the column that is the status in the simp rep (so excluded).
2) sincerely I did not understand .. the excluded components should not see them and therefore if even a mistake do not see it.
Good morning.
thank you go and apologize for the delay in the answer,
1) ok this now I am clear
2) Now I have understood, practically if a model not recalled in the simplified rapp. (for example a component of a machine that being inside I do not want to show) has an error and I have previously opened it in master replica, the error I find it also in the simplified, if instead I open directly the simplified, the error I do not see it.
Thanks again;)
Thanks again;)
exact
