simplified representations sum
  • Thread starter Thread starter nicolac
nicolac
Hi, everyone, I wanted to ask, I have a set with parts inside,
I have to do some phases of work with semp representations, that phases of construction of the piece, I have 2 or 3 phases single part with part that are to be welded between them (representation semp) , then the welders will have to assemble these parts that I put in the sp replies, in a mask phase,
in the mask phase (always a rap semp) I wanted to insert type( rapr n3 together with 1)without having to re-check part by part, but all the elements that make up the rep1 e3, which becomes n4, then I would like to make like a rule where if I add parts to rap 1, see in 4
Can't you give me an example with some desktop image?
Can't you use a set in which you insert the two assemblies (as sub-assiems) with the individual representations?
Perhaps I can use it, but I should also use tables and bubbles with the number of the right components, in the sense. If there are total n10 slid dice, in the table that I made should jump out 10 pieces... Does the cartilage in the modalita design then take into account the hidden parts of the simplified representations or does not count them?
the only thing is that I should do 10 single assemblies of parts assembled together, then the coax 1 with the 2, the result with the 3 and so on, I don't know that in your way is the right direction?
