simulation screws
  • Thread starter Thread starter Lucky Luka
Lucky Luka
hello to all
is it possible to model in solidworks simulation of threaded joints with clamping screws?
Of course I do. There are the proper connectors that they make as screws. even if this was not there would be no problem because you can decide to model hole and screw, meshare fine and see the result....even if all this does not make sense because you use the norms, like uni en 1993-1-8.
Thanks for the answer.
Trying and retrying I still couldn't get the desired result.
as you see in the attachment I have crated a screw connector biting specifying the edge of the hole in contact with the head of the screw and the threaded part.
It can first be noted that the screw is not properly dimensioned also the screw that I would have wanted should have cylindrical head with hexagon recessed but here it seems that the choice is that of a hexagonal screw. . .
Can someone tell me where I'm wrong?
