simulation star ccm with method discreet elements
  • Thread starter Thread starter tailele
tailele
Good morning to all... I'd like to ask you for advice for a simulation. I should simulate a material discharge from a container with quite particular shape. I read the two tutorials's provided with the program, so momentarily there should be no problem of boundary conditions or physics. the main problem concerns the filling of the silos. in fact the question I would like to ask you and the following: does not exist a method to start already with the silos filled with material? because in the tutorial's fill the container with injectors. I have also done this procedure, but I lose a lot of time to do an operation that I actually do not need because I only need the discharge. for this reason I ask you if there is a setting to start the simulation with loaded material. Thank you so much.
