ceccagoal
Good day to all, it's the first time I've been writing excuse me if I do some gaffe but I've never written in a forum, I have a problem and I would like to know if there is anyone here who can route me politely. I practically have to deal with a platform that has to mate with two other equal extensions through plates with holes. I was asked through solidworks if I can perform a simulation to find the optimal tolerance ranges in geometric terms. I explain better practically there is a central frame and on its sides I have to connect these two extensions verifying that you do not create a step in terms of height due to the coupling with the plates and that everything remains orthogonal respect a reference plan would be that of support of the entire structure sove are the wheels, moreover once coupled there is a tolerance of parallelism of 0.5 between the extreme sides of the structure in time is a structure in all about 4 meters I attach a photo of the structure to make you understand better. my question is how to do with solid works to assign on the 3d tolerances with their ranges the reference plans and then simulate the software that the tolerance ranges set are right or can be enlarged to save on costs? thanks for the attention
