single-cut tool for spying
  • Thread starter Thread starter body
body
I remember at the time of the school that to spy with the traditional milling machine was used a mono-cutting tool that, I think, we called "bilancino".some owns the design or can explain how it could be realized?
thanks and a greeting to all.
do you mean that with a cutting edge in hss (parlo of self-built stuff) mounted on a radially adjustable arm compared to the rotation axis? some kind of bareno. .
I do not have drawings (always built on the flight in the workshop), but it takes a moment to do so.. and some photos on the net should be.
Mar
Sorry the delay in the answer
this type of "barnes" also exist of commercial type even if it is now struggling to find them
in normal are tools that you make at home
just have any support that you apply to the cone or any type of stem that you vade in the pliers
just make a "lateral" hole insert any kind of tool and keep it steady with grains
typically recovering ground tools
as men in broken steel inserts for heads"andrea" etc.
usually this type of tool is used when there are probes of overheating
example thin plates to smooth
the theory or philosophical thought said that having only one tool to contact
with the piece to fresare did not overheat
Surely it was used for dry sanding like cast irons
or if you wanted a special finish on aluminum plates
or when years ago the economy of small companies planned
recycling all broken tools
or save on emulsifying oils
Big way was the time when money was spinning a few
(it seems today: mad:)
Good Sunday
Well yes, those are commercial, professional, technological, micrometric. .
I was talking about the same thing but self-constructed in the workshop:biggrin:
as it says shiren a couple of grains and seals all radially.
Marco:smile:
Yes, you are right, it was just to give a reference link, then as you rightly say, and also shiren, you can build quietly. . .
Bye!
p-h
p.s.: of those self-built in the workshop we have different for all needs, you know how many times we still use them today? :finger:
we also have technologically more advanced ones... :biggrin:
Marco:smile:
cja marcone
There's between the two types that trade and the craftsman.
na small difference
minimum 3000€
those placed are a derivation of the original idea of the endorea
for my humble and modest experience:biggrin:
I used-use-used only and always of erea
to the face of all Asian junk:finger:
