nanneddu
Hello everyone, I have a poblem on a catwalk. the piston that regulates the climb and the descent is simple effect, comes only a tube. In addition to the electrovalve that commands the function from the water control unit there is another electrovalve put at the exit of the piston that should serve to make as a lock valve. the problem is that when the control unit leaves and makes the electrovalve opening the catwalk sometimes falls also 60 cm from the horizontal line as if the oil went back without obstruction. I think the problem is due to the fact that when the card gives the consent to the solenoid valves to open the motor of the control unit has not yet pressed the plant, therefore causing the famous fall of itching. I thought I would somehow delay some fractions of a second the arrival of voltage to the valves or insert a piloted lock valve with simple effect, but where do I connect the opening pilot pressure tube? Help me thank you
