single safety output for continuous façade
  • Thread starter Thread starter kitelakes
kitelakes
I am looking for, and not finding it, a single safety exit in crystal, to be inserted in the continuous facade.
I attach the double door exit, I would like the same but single.
I also tried, uselessly, to edit the rfa file but I failed.
p.s. I couldn't even attach the rfa file of the double door, but because it's all complicated:)
to add the port file (rfa) you must attach it in compressed format (zip), using the "go to the advanced mode" button (at the bottom of the page).
you can create the single door, using the glass door in the defaul families of revit, adding to the same the "pump handle" that you find on the families of the "rei doors" that are inserted in the forum "freedoms of families and objects"
Sorry gfrank, I didn't specify, security exit to be inserted in the continuous facade
