size-direction sheet layout
  • Thread starter Thread starter JACKFRAU82
JACKFRAU82
Good morning, I use a 2013 autocad at work, I need to change a setting, explain better:
in the layout, when I change the sheet format, it enlarges or shrinks always to the right, I would like to reverse the direction towards which the sheet sizes go, then to the left, since in my company we produce tables or processed for customers, and the presentation mask we always place it right.
If someone helps me, I'd be glad.
What do you mean to change sheet size?
I make an example: inside a layout with a0 format, place on the bottom right the mask for the table (image 01) , if I want to change from a0 to1, I go on the page setting window and from the list of the sheets select to1, when I return to the layout, the mask at the bottom right is me out of the sheet, then as the base point is imposed downwards (image 02)... 01.webp02.webp
If you have an a0 and want to print it in a1 it is wrong the starting concept.
if you do not want or you can use the correct format do suitable page and you are in place
See that most likely your cartilage is a block.
select it and press right button, from the curtain opening select the item editor blocks and now you can fix the mask simply with the move command
save everything to find the modifications of the cartiglio in the paper space.
It does not seem to me a problem of paper, but of printing, in fact both images and explanation
JACKFRAU82 said:
Page setting window and from the list of sheets select a1, when I return to the layout, the mask at the bottom right is outside me from the
You mean you're talking about the press.
