size does not match reality
  • Thread starter Thread starter oloap72
oloap72
SmartSelect_20231025-185656_Gallery.jpghello to all, I realized that the size of catia does not correspond to reality. As the size increases, the error increases accordingly, I cannot understand whether it depends on the table settings, or upstream on the model. Can anyone give me a tip?
Thank you so much in advance!
if I understand correctly it is a development of sheet with bending.
Right?
if you probably the k factor for the calculation of the view with development is not correct.
Let us know
no, it is a simple modeling solid to create a chassis of a rc model. I worked in non sheet metal modeling environment
I checked the printer parameters, they were suitable for the page and not on real size.
problem solved👍
