size in raw in properties
emanuele grasso
Is there a way to compile between the properties added one that gives me the raw of the component?
What kind of variable do I have to assign to the "gree" property?
Of course.
with powercopy, create a function that returns "xmin" xmax" "ymin" "ymax" "zmin" "zmax" "zmax"
the differences three minimum and maximum steps to a variable for example "dimensions"
size="+dimx +"x" +dimy +"x" +dimz
varying the size of the partbody vary the size automatically
I have what you see in the annex "poly-line". .
I have already looked in that box and there is in fact you have 3 commands and I 2
to calculate the extremes you have to use thisView attachment 69055
If I understood the request well and in this specific case (as the license seems limited and do not think it is the case of going through programming or similar given the other questions ), I think there is a workaround , going through 2 floors (for each extreme ) .
that command of the attachment calculates the extreme points max and min in x in y and z
once you find the points max and min.
with the "distance" function you extract the size of the piece.
then if you pair with powercopy (I believe it is default in all licenses) you can create a fast automastism that defines the extremes and calculates the maximum size of the partbody.
so I did
the alternative, in the absence of the command, is to create points and plans, but on a different shape from a simple parallelepiped is very challenging if not impossible.
cmq is absurd....... i x example having the cam i activate a command in gsd that creates the rough of the piece to fresare , and wanting also the orientation , should be by default in all configurations .................. but unfortunately everything is paid
