size
  • Thread starter Thread starter tomahawk64
tomahawk64
Good morning to all,
I would like to know how it can be exported into the separate components of a set (excel format) the 3 dimensions, or the two for a round indicating the maximum bulk of the part?
I thank in advance all those who will answer me.
This procedure may apply to any type of parameter added in metadata.
1. create an excel file with x, y and z peste per column on the second column adding the 0 mm value (always adjust the measuring unit).
2. open a file type part
3. Right-click on the root of the tree and on the segliete property pop-up menu.
4. click on the "Define Other Propie" button
5. click on the "external file" button (it seems to me, however it is the last button in the window)
6. import the properties to lock the fimesters and save the file, in a protected area must become the template for every future file you create, for those already created you will have to import the excel file.
7. inserted a series of files with these parameters in a set, and called the "bom" command, click on "define formats".
8. in the list of fields for the creation of the bom you will also find the xyz values that you have created el i you can add to your customization.
