sizing/dispensing waste water discharge pipe.
  • Thread starter Thread starter New Rider
New Rider
Good evening to you.
First of all, I do not come from the construction industry but from the industrial sector, being a mechanical expert.
I also hope to post in the right section. otherwise correct.
So... I am studying an example in large lines of a wastewater flow system. this outflow system will be installed
hypothetically on a square rather than a small road/way.
the system will consist of caditories, inspection/filter wells and pipes.
I would like to know from you first of all beyond the calculations that will follow after, do there exist methodical/theorical dispenses on this type of works? possibly of the regulations in which to understand a moment the topic.
Moreover, a question that has arisen from the very beginning, how is the air/fluid exchange between the external environment and the underground pipes managed?
(I do not know how they are defined in technical jargon but to understand us: air flows, air bags etc. )
thanks for the collaboration.
