skeleton motion
  • Thread starter Thread starter blubossa
blubossa
I'm trying to understand and use skeleton motion, I did a test by joining 4 levers but at the time when I have to do cinematism I get rid of everything..... despite the fact that I told him to hook up to the body....
allego proves hoping someone will help me... .
bb
I'd say you're on the wrong road. first of all the skeleton is an object that is associated with a set as the first element. In that part you must define the geometry that, in the main one, is in fact a frame. then there are the elements that are assembled with kinematic constraints . These elements better be sub-axioms with its skels. I would say that first of all you have to study well the film constraints: cylinder , pin, frame etc. find them as an option when you check anything.
test
Hello makeng,
I know them pretty well, but I didn't understand how to operate. . .
I try to reread the manual...:frown:
bb
I think I understand.
I have corrected the axieme and it works now but I can't understand changing the sketch everything goes wrong, and also how do I give it constraints for example of degrees, or translation?
I attach files.
bb
