sketchup not working on my computer
Marco_m
Good morning to all,
My problem with sketch up 2022 is that I have a file of a house with a courteous area (weight 62 896kb) that is blocking my computer; I can't turn the camera and start rendering with v-ray. (I often close the program independently)
I tried to open the file with a computer with: i5 2.70ghz, 8gb ram and nvidia gtx 950m graphics card;
both with a pc with better components: i7 2.70ghz, 12gb ram and dedicated graphics card nvidia
I have already looked on the internet on how to lighten the file weight as much as possible, but there were no visible improvements
I am currently using the 30-day trial version, can it be that it has reduced performance? (on the site they do not say that it has reduced performance, at most they tell you that all features are not available)
I hope you can help me solve
Thank you very much
Since you're using a 30-day trial, why not try version 2023? Maybe it's more performing
v-ray significantly slows down the pc.
try to disable it from "management extensions" and you will see that the pc will be much faster.
at that point you set all your cameras and your views and then you react to it just to make the rendering.
to reduce size and eliminate unnecessary things, you can use tig programmer purgeall:
Staff online
