sketchup - photomapping ostico
meromero
I am reporting a photomapping of the facade of a church on a volumetric stunt, however some areas are delimited by the lines that design, while others are assigned outside the lines that design.
For example, edges and bases of a column are delimited, so just select the column area, use the command that makes it rise in the detected and get the column with texture the column area of the column.
in other cases, however, the rectangle or trapeze that defines an area if selected remains connected to the adjacent textures.
Is it a sketchup algorithm bug that assigns areas of a photo to a surface or some error I make?
if you need to place some img of the problem.
