sl and sls: 3d printing of proto labsindustrial 3d printing is an additive manufacturing process that gives the possibility to realize prototypes in rapid times that have the desired aesthetic characteristics and that respond to the mechanical specifications necessary to overcome the stages of testing and testing.[TABLE="width: 660"]
<tbody></tbody>[TR][TD][TABLE="width: 350"]
[/TD][/TR]
[/TABLE][/TD][TD]proto labs is the ideal partner in industrial 3d printing, able to propose a complete offer of prototypes and products in reduced volumes realized by stereolitography (sl) e selective laser sintering (sls) for polymers and direct laser sintering of metals (dmls).
stereolitography consists of laser curing of successive layers of thermo-hardening resin that, following repeated steps, allows to achieve the growth of the desired component. the advantages of stereolitography are the excellent surface finishing, the ability to work complex geometries and the cost contained.[/TD][/TR]
[/TABLE]selective laser sintering (sls) uses a laser beam to melt different types of powdered materials, such as nylon, from below up; thanks to the high resistance of the components so obtained, the sls is the 3d printing process perfect to realize functional prototypes to the phases of testing and testing.
proto labs supports 3d printing technology to two other services: lo stampaggio injection and processing mechanics with cnc machines thus ensuring the maximum speed of execution of your projects.
