slowness
  • Thread starter Thread starter MarcoAtk
MarcoAtk
I don't know if it only happens to me and, if yes, because, but sc is stra-lento to save even simple stuff and sometimes gives me the message "not respond" and stops thinking interrupting the workflow... even for little stuff, like I make a circle, a line to turn into construction geometry, for example.
I try to disable automatic rescue and see!
Mar
Mar
This is a more complex problem... you should contact your provider and give some log files + info on operating system and hardware. . .
the files you produce are great? if you save a blank file how big it is?
Bye-bye.
I hope you can be my supplier soon:biggrin:
I test the empty file hangs back in the other office.
an empty file is 56kbyte... little stuff.
the first product file is 520kbyte if not internalized, otherwise it is 250mega.
ideas?
It's a very complex distributor. sw also went a bit in crisis.
How do I count the objects? I mean, even those nested inside the others... All solids, practically.
to count the solid right-click presses, select everything and below (in the bottom right bar) read the number of bodies (solids+surfaces) surfaces normally you should not have... then the number of solids=number bodies
Something's up.
They select everything in the main axieme (which contains others) and tells me that they are 200 bodies; one of the subaxiemes contains 9020. so would I say that the select everything selects the elements of the current axieme?
However, take into account that only one sheet contains itself (as sheet) with another 100 repeated components that are electro-welded prisoners and threaded inserts.
so to nose making the sum of the various subaxis is easy to reach 12000 bodies.
Something's up.
yes I said right button on the work space (on white, empty) and select everything. will really select everything and not the components... but it is clear that prisoners and other falsify the count.
Yes, I did.
I made the main axieme active and did select everything with everything displayed: 11.132 bodies.
then the main parts will be 300.
Is he right to be slow?
The problem is that my projects for a couple of years are all so...
