snap on the table
  • Thread starter Thread starter andrea1974
andrea1974
Good morning, sometimes it happens that, on the table, listing, if you zoom closely in the quotations do not stick while from far away you. Do you have to set the snaps somewhere?
igo image
Now I have deliberately removed it, but I can't stand up... from far away
igo image
If the problem is to align the odds, I recommend using the appropriate command. so besides being aligned, they remain hooked if the moves.
hi re-solidworks, I understand that gorea1974 is at first arms or little more, you could indicate what is the specific command....
is also used "parallel/concentric quota alignment" but only works after putting the quota series
