snippet in wb ed error
  • Thread starter Thread starter piersilvio
piersilvio
Hello everyone, once again I find myself asking for advice on a problem never solved. It is a simple beam supported with 2 concentrated symmetric loads. the beam must be shaped with concrete material with fragile characteristics and therefore with possible cracking. in environment wb 14 proceed in this way:
1) under the geometry of the solid model the solid with solid elements65 [ET, matid, solid65];
definisco le caratteristiche del materiale del quale posto l'intero contenuto :
! commands inserted into this file will be executed just after material definitions in /prep7.
! the material number for this body is equal to the parameter "matid".
! active unit system in workbench when this object was created: metric (m, kg, n, s, v, a) with temperature units of c
et, matid, solid65
mptemp,,,,,,,,
mptemp,1,0
mpdata,ex,matid,,3,5e6
mpdata,prxy,matid,,0.2
tb,conc,matid,1,9,
tbtemp,0
tbdata,,0.2,0.9,0.4e6,4e6,0,0
tbdata,,0,0,-1,,,
2) in analisi statica strutturale ho impostare i controlli non lineare:
numero max di iterazioni, large deflection, numero di steps.. etc.
3) lancio l'analisi ma purtroppo fallisce immediatamente nel momento in cui il solutore riceve in pasto il tutto con il seguente errore:
error :"an internal solution magnitude limit was exceeded.
please check your environment for inappropriate load values or insufficient supports.
also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.
please see the troubleshooting section of the help system for more information".
warning :
"solver pivot warnings have been encountered during the solution.
this is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues.
check results carefully".
l'analisi viene invece condotta regolarmente se non inserisco snippet e lascio un materiele elastico lineare. ma dove sbaglio???:confused:
avrei un altra domanda da porre: se dovessi evidenziare le fessure create con il comando pl*****, in quel punto del ramo solution devo inserireìle e secondo quale sintassi?
grazie a tutti colore che avranno la pazienza di leggere questo lungo post e rispondere.
thanks first of all for the answer. .
I must think then that model probably for that kind of material has ineffective contacts? i.e. the constraints are steel plates (supports) externally bound with frames and fixed on the beam with bounded contacts.
Perhaps deformations are established to make the beam mobile.
Thanks again. .
I will try to change the conditions of bond
