software 3d render
  • Thread starter Thread starter Simconti
Simconti
I don't know if it's the right section, in case it wasn't: sorry the mistake.
1 - currently in Italy which is the most used 3d software? (render and construction 3d).
2 - which is the best of you?
3 - starting from a dwg of an architectural project, with which 3d subvert is obtained the most photorealistic result?
I try to answer considering that you speak only of sw to make, and not bim, cad etc:
1- most likely 3d studio max
2- impossible to say, everyone has its own peculiarities, and everyone is well with what he has chosen to use, the thing is extremely subjective, at least with sw of a certain level
3- all renders, if used well give results practically coincident with a true photograph, however, it is likely that the best ones from this point of view are the physically correct ones, called unbiased, such as maxwell render and fryrender, which are the most known and widespread of this type, but are also among the slowest in the calculation phase, but among the fastest and easiest in the setting of the parameters.
for choosing a motor to make the rule however is: it depends on what you have to do and how you have to do it, and you have to try them first, to see if you like the workflow ;)
Gazie for the answer.
I add a question: also use 3ds max or 4d cinema, then to make you need a sw like vray?
no...or also yes.:) in the sense that both sw have both engines to render high-level interior, especially 3d study with mental ray, and external, as plugin. can be a choice. Many use vray in 3ds because it is very fast and of very high quality, but with mental ray you can do the same quietly. maxwell render can be used as well as alone, in both sw mentioned by you.
depends on where you are. in the guild use a lot of microstations, to make an example, here you go on the safe with autocad, archicad, 3d studio, rhinoceros.
You have a good resume if you can use more than one. :
by foster requires microstation in fact. but on the ads of gumtree often require autocad designers (rarely vectoworks) and 3dsmax
