solid edge drafttools
  • Thread starter Thread starter Be_on_edge
Be_on_edge
solid edge utility to simultaneously edit some items in draft files
from the sinister to the right
  • select all horizontal quotas
  • select all vertical quotas
  • solid background in texts
  • position the shutters on the outside\ inside
  • change the shutters from arrow to point
  • add interrupting projection lines
  • remove interrupting projection lines
  • center the view in orizontale
  • center vertical view
the tool works on the current selection, you can change and selection and continue to use it
the instrument can be left open and used when necessary
last release at this link: releases · Farfilli/solidedge-drafttoolsto questo link: github - farfilli/solidedge-drafttools: solid edge utility to change multiple draft objects characteristic at the same time
downloaded 2 times but does not open me with 7zip. My problem? I have no way to try on other pcs.
error message is "impossible to open the file as archive.
Thank you, Frank.
Unfortunately I can't open it but at this point I think it's a problem of my pc, tonight I try to open it from home if I remember.
