solid multi-section: how does it work?
  • Thread starter Thread starter alex369
alex369
Hello, guys.
today I tried to shape a solid with the feature of the multi-section but I receive a mistake that I don't know how to solve, I explain better:
I have the following 3 profilesif I try to make the solid between the central profile and the one on its left, all perfect:if instead I try to make the solid between the central profile and the right one, I receive error because the software places the closing points in the opposite position (see yellow circles):How can I change the closing points of a profile?
Hello alex369,
to be able to change the closing point on a profile you must go with the mouse cursor over what you want to change (or on the written closing point in the drawing area or on the specific point selected under the closing point column in the multisection solid command window) -> mouse button -> replace -> select in the graphic area the point of the same profile you feel most appropriate.
Hello alex369,
Thank you so much!
