solid works motion
  • Thread starter Thread starter Joel
Joel
Hello everyone,
I am new in this forum and I wanted to ask for information. I am drawing a suspension system, now I have finished with the design of the steering pin. But now I would like to check the cinematics with solidworks, I know that I need solidworks motion, but I don't know if it's already installed in the premium solidworks package or do I have to fix it somewhere else? What if the program starts? ? .
thanks to all
hi soliduser,
I did as you wrote, but I did not find solid motion, there are other tools (which I added anyway) but not solid motions (however I have premium solid motions 2009). However I wanted to understand if solid motion would be "movement study" which is located next to the model card (where the 3d drawing is carried out).
hi soliduser,
possible errors are being installed or after, inserting a non premium code.
the code during installation defines what it installs.
If for example you put a base code, he only installs the base.
If then once installed, change the license and pass to premium, now it is too late, you have to change the installation.
hi soliduser,
motion is activated with motion analysis.
