redjump
Hello, guys, is there someone using solidcast?
Thank you! ! !
Thank you! ! !
but technology profes never explain it to anyone how to use this program?! I used it for the design but not working on windows 7 I no longer installed it (comuqnue is the license would expire). you had to set 3-4 parameters but I don't remember much... material type of casting, shape and something else. you can import saved designs into stlHello, guys, is there someone using solidcast?
Thank you! ! !
Seeeee... look that engineering profes don't know how to use these programs. It's a lot if they know excel and matlabbut the technology profes never explain it to anyone how to use this program? !
the problem is that I don't know how to install it, do I have to buy it?you how did you get it?but technology profes never explain it to anyone how to use this program?! I used it for the design but not working on windows 7 I no longer installed it (comuqnue is the license would expire). you had to set 3-4 parameters but I don't remember much... material type of casting, shape and something else. you can import saved designs into stl
