solidwork cart
  • Thread starter Thread starter PaoloR1
PaoloR1
hello to all my name is paolo tiziani, I am an independent industrial designer (with p.iva). in my study I use inventor and mechanical, but I am about to evaluate the transition to solidwork. Of course I have all the files of my clients in format or .dwg or .idw.
question: Do I have the possibility to put in the folder "chartles" of solidwork the aforementioned files or do I have to give them back in the correct format? If I have to give it back, there is a sheet "without" cartilage, where to go to realize a new cartilage?
Forgive ignorance, but before I go to solidwork, I would like to understand the amount of work I'm meeting with.
Thank you and hello.
topic treated dozens of times.
do an advanced search with the stationary voice and the solidworks section. you have to create two types of files: in design model is a sheet format for any type of teaming you use. made once you are in place; You'll take a couple of days. This is certainly not the parameter to evaluate the burden of software change....
However you can import for each format model, the dwg of the score and the customer's cartilage but you have to add the fields in the models and in the cartilage for compilation
