solidwork drawing corrections
  • Thread starter Thread starter unknow Error
drawing was to make the table if I did not mistake then there was together that it served to merge more solid and then part (that and what I used to make the drawing).
I continue not to understand why it is wrong to use part , in my solid work there are only these three possibilities. . .
I looked at him... You've done too many functions, you've done three floors that don't need anything.
I attach the part model as it should have been
the post start design is obscene, besides being quoted by dogs also lack some quotas and it is a very trivial element; with this kind of material you will never learn anything
what is not clear of "indicates in the profiles the version of solid "?
There is no version 18-19, or 2018 or 2019. as you can not open future version know the correct version is important not to download and try to open incompatible files... otre to give correct advice
if it is the student version does not open anything with the work version.
I have just started using solid work (by self-taught) and I am performing simple drawings (drawings found on the web) to practice, and I would like to ask if someone was willing to correct my work ,disputing any errors and giving me advice on strategies to adopt. Thank you.
allego drawings
ps can you tell me how to load the drawing performed on solid work as well?
you do not make quotas inside the drawings and you do all beautiful aligned.
I suggest you take books or drawing dispensers and start from the bases....then start with solidworks tutorials and then you can start doing something of yours.
open quickly at lunch break. esce l'alert that it is a file made with student version, but it opens without problems.
Maybe he might have trouble opening up what I did even though it's an older version of his
He didn't do the design, but he found it on the net.
ah....ok
then because a person who knows nothing about mechanical technology, technical design and has diametrically opposed studies puts himself to use purely technical software remains a mystery, at least for me
many psychologists do it, massive, for the pure professional curiosity to understand how crazy are those who use it all day for years and years....
Mah, so much rush to learn and then puff... disappeared, that houdini would stand aside. ♪
