solidworks 2021_use of variables in couplings
  • Thread starter Thread starter Marco@ccmairports
Marco@ccmairports
Good morning.
Can someone tell me how to assign a variable, already created through the equation table, to the value of a distance in different pairs so that you can change all the distances to which the variable one has been assigned?
Mar
enter the editor of the quota, write = and select the variable to which to connect it.
with the quotas in fact we do so. but if you try to do it when you are setting the distance value in a coupling you will see that it does not work.
But I found out there's another way. Thanks the same.
You are right; I am a "absolute beginner" of the forums and I had not thought about it. remedy immediately.
I found that, by grouping all the similar works in a folder (from the list with the two scratches at the bottom of the working tree in the assemblies), you can edit them all in one shot (dx key. on the folder you created -> changes functions) and so I got the same result.
