stefano1984
on my pc I have windows seven 64 bit! what version of solidworks can I install? only 64 bits or can I install and use one to 32 without problems? thanks for the help
in my office I have mixed versions and os: xp32 - xp64 - seven64. bugs I found do not depend at all on the 64-bit version as I find them identical on machines with xp 32. I use mostly 64-bit versions and I find that stability is almost identical, of course if with 32 you remain within the limits of complexity manageable with a 32.Good evening to both of you,
the fact of using solidworks 32 or 64 bits should arise from a real need for volume and complexity of geometry. in practice you have that:
in 32bit everything works, compatible all in all versions on all 32-bit systems
in 64bit does not work everything, there are incompatibilities between solid version and win version...but bug fixes are always updated
However,
in 32bit everything turns slower, you can use little ram while in 64bit push what you want.
stefano, in particular, if you have windows x64 it would be better to use solidworks x64 even if you can install the 32bit version on a 64bit operating system thanks to the native emulation of windows. the opposite is not possible.
good installation
I will be obliged to change.Bye to all,
reconnecting me to some other posts is evaluating the fateful passage.. - We're in the case.
In the office, however, we have a tide of 32-bit native and living programs (sometimes freeware and sometimes paid fior of money es mathcad) and sometimes managed by servers to distribute licenses).
- Does anyone have practical experience with xpmode?
- xpmode draws on server licenses?
- last but not least embarrassing:
we have office 2003. Do you have to change that?
"I think it would be impossible for solidworks to invoke excel through xpmode"
Has anyone been burned yet? from us the risk is to put a badge and blush because you have not remembered everything.
Thank you for your help,
dancer
It's just like that, and it's always been like this, if you don't have the privileges, and you can just read and write nothing goes... was so already with sw2006Hi.
I am verifying the operation of solidworks 2010 on a machine with windows 7 64 bit and the program crashes if I try to create a design (it provides a generic error and closes the program) with a power user. if I use a user administrator the program does not give any error.
on pc with windows xp 32 bits this problem is not there.
Has anyone faced this problem?
Unfortunately at company level users must have the power user rights and the issue is getting edgy. the retailer said that the program should only be used with a user who has administrator rights, it seems strange to me that there can be no solution.
We have a "old" dj 1055cm that is still perfect.. I can't find drivers and I can't make it work with win7. Unfortunately these are things I didn't think when I got the ws.. as well as the fact that win7 is not compatible on the network with linux servers (or at least in a network with "mixed" utilities), but this for now the programmer has solved it (I have not understood that "patch" has installed. but it is not yet definitive, it seems a "beta"), only that with xp while being user I had "administrator rights" at least as far as I was concerned (freedom to install programs, updates, intervene on the so etc.). But now with seven I'm stuck in everything and I can't do anything anymore.. and you know that with swx is a mess. says the programmer/assistant that even this with the definitive "patch" will solve.. Hopefully.I had to "push" an old designjet 350 c that still worked well (I still use it with the last surviving xp32).
xp mode is a fetecchia in the sense that turns very slow, it seems to use the pc remotely, I would exclude the use.
seven is young and some youthful poop has it. what I have noticed is that once the pc is developed it is faster than xp or xpx64.
errors can also occur in programs, but the system never stacks.
I also had to scrap my 350c with regret (unfortunately after more than 10 years of uninterrupted work an irreparable failure to the heads lock...:frownis not a problem of solidworks or patches, it is the hp that does not make drivers. for designjet I did not find the following drivers to xp 32 bits, so xp 64, view and 7 are out.
you can try to use it with windows drivers, but more than the test page I know you don't print.
another alternative is to try with the drivers of another plotter (in my case 430), but the result was negative.
I know. I said that for networking problems (with linux servers).is not a problem of solidworks or patches, it is the hp that does not make drivers.
no, for mine it seems to me that until view64 there are (I remember having seen them looking at the site hp).. If it's true, I'll try with those.for designjet I did not find the following drivers to xp 32 bits, so xp 64, view and 7 are out..
Don't tell me that I have to change that plotter, in company they scotennano me (incauto purchase of ws with seven); works perfectly and at the time had cost around 13 million lire.you can try to use it with windows drivers, but more than the test page I know you don't print.
should not be scolded because with solidworks 2011 I think xp is no longer supported.Don't tell me that I have to change that plotter, in company they scotennano me (incauto purchase of ws with seven); works perfectly and at the time had cost around 13 million lire.
and I wouldn't want to downgrade to xp.
but computer science, software and hardware make you mad.
Mar
Yeah. .should not be scolded because with solidworks 2011 I think xp is no longer supported.
Let us know.I perhaps (and I repeat perhaps) have solved with this:
http://www.winline.com/What's going on?
http://www.paolocasella.it/I made a quote.
hello and a thousand thanks for this link. my designjet 350 is still perfectly working and I am using it with the last xp 32 in the office. I was willing to throw it as soon as I passed to 7 even this last pc and if everything goes well I still keep it. for the moment I compiled the form and asked to be contacted.I perhaps (and I repeat perhaps) have solved with this:
